AIMMS PRO REST API Updates
The AIMMS PRO REST API is available only on the AIMMS Cloud Platform; it is not supported on on-premise PRO installations.
Task Scheduler (Version 26.2.3.0 - Novemeber 23, 2026)
  • Improvements
    • Queued tasks now start in first-in-first-out order across all apps in an account, including scheduled and recurring tasks once they are due. An app with many queued tasks no longer holds up tasks from other apps that were submitted earlier. Sessions are still reuse when the next task belongs to the same app. When tasks from different apps alternate, sessions may be started fresh more often. See documentation for details.
Task Scheduler (Version 26.2.1.0 - September 1, 2026)
  • Resolved Issue
    • Task sessions now use the correct account-specific pro-aimms-session bootstrap artifact, matching the one used by the Session Manager for interactive sessions, instead of a single static default. This ensures accounts pinned to a specific session artifact (e.g. one with a custom injected DLL) get consistent behavior across task and interactive sessions.
Task Scheduler (Version 26.1.3.0 - June 29, 2026)
  • Resolved Issue
    • Task Scheduler now downloads the bootstrapper from the correct regional CDN.
Task Scheduler (Version 26.1.2.0 - March 24, 2026)
  • Resolved Issue
    • Fixed an issue where recurring tasks could fail with error - Downloading request blob failed with a 403 status and 0 error code due to an expired request SAS URI. The Task Scheduler now automatically renews the SAS URI on each scheduled run, which resolves the issue.
Task Scheduler (Version 26.1.1.0 - February 3, 2026)
  • Improvements
    • Added support for binary input in task requests.
    • Increased the bearer token time-to-live (TTL) to 3 minutes to improve request reliability.
Secret Manager (Version 26.2.1.0 - January 29, 2026)
Improvements
  • Added support for sorting items and introduced additional item metadata.
Secret Manager (Version 26.1.1.1 - January 9, 2026)
The AIMMS PRO REST API is extended with the secret-manager service, enabling secure management of customer and user secrets within the PRO environment.
Please see the documentation and API Specs for more details.
Session Manager (Version 25.6.1.0 - December 12, 2025)
New
  • Session ID retrieval: New procedure pro::sessionmanager::GetSessionId allows programmatic access to the active AIMMS session ID.
  • Unified service access: pro::sessionmanager::GetServiceAccess now provides both the service URI and bearer token in a single call.
  • Service URI API: New endpoint GET /pro/session-manager/v1/sessions/{session_id}/{service}/uri to retrieve service endpoints via REST.
  • Token exchange API: New endpoint POST /pro/auth/v1/token/exchange for obtaining scoped bearer tokens with configurable path and access level.
Improvements
  • Streamlined, consistent workflow for accessing cloud-hosted services (session → URI → token → access).
  • Support for predefined services such as WebUI and Dex.
Please refer to the detailed documentation for usage instructions.
Use Case
  • These enhancements directly support MCP, which relies on the new session-based access flow to securely obtain service URIs and bearer tokens. MCP can now interact with AIMMS cloud services using the standardized and fully supported API workflow. A key example of this is the upcoming release of SENSAI Pro in AIMMS SCNavigator, where these improvements enable seamless and secure integration.
Session Manager (Version 25.2.1.0 - April 15, 2025)
  • Solve Sessions Support
    • The Session Manager REST API now supports Solve sessions, extending its capabilities beyond WebUI and Task sessions.
  • Endpoint Enhancements
    • The DELETE endpoint is now split into two distinct actions: terminate and delete, allowing for more granular session control.
    • Endpoints for retrieving session logs have been updated for improved clarity and consistency.
Task Scheduler (Version 25.1.1.0 - April 15, 2025)
  • Endpoint Update
    • The appName and appVersion parameters in the GET /tasks endpoint are now optional. This allows more flexible queries when retrieving tasks owned by the user.
    • GET and POST endpoints now include two new response fields: userName, userEnvironment
Task Scheduler (Version 25.2.1.0 - May 15, 2025)
  • New Endpoint
    • GET /tasks/{id}/logs: Introduced a new endpoint to retrieve task logs.
