AIMMS PRO Cloud Updates
PRO Cloud build release notes for the AIMMS Cloud Platform pipeline, starting from the point where AIMMS PRO Cloud and on-premise builds diverged. For releases before that split, see the AIMMS PRO Release Notes Archive.
PRO 26.6
AIMMS PRO 26.6.4 Release
On November 5, 2026 we released AIMMS PRO 26.6.4(Cloud build: 26.6.4.1)
Resolved Issues
AIMMS PRO AppLauncher shown as coming from an unknown publisher: The AppLauncher (
AimmsPROAppLauncher.exe), used for example to run WinUI apps, was still a 2023 build. It was signed with a certificate that has since expired, and the signature had no time stamp, so Windows reported an unknown publisher during installation. PRO now ships the current AppLauncher, signed with a time stamp so the signature stays valid after the certificate expires.
Security Fixes
Upgraded several bundled third-party components to resolve known vulnerabilities:
Jackson2.18.12,Jetty12.0.39,Netty4.1.139.Final,Bouncy Castle1.86,Guava33.7.2-jre,Apache Directory LDAP API2.1.9,jsoup1.23.2,Apache MINA2.2.8,OpenSSL3.5.9,Expat2.10.0 andBrotli1.2.1.RapidJSONis no longer included.The networking library used by the PRO session now disables TLS 1.0 and TLS 1.1 by default.
AIMMS PRO 26.6.3 Release
On October 1, 2026 we released AIMMS PRO 26.6.3(build: 26.6.3.4)
Resolved Issues
Publishing an application under a previously used name: Publishing a new application with the same name as an existing application could cause problems with the folder permissions in PRO Storage. PRO now blocks this and shows an error message. To continue, publish the application as a new version of the existing application, or choose a different name. If the earlier application has been deleted, you can publish a new application with that name.
WebUI sessions failing to start because of unavailable libraries: Since the release of AIMMS 26.3, some WebUI sessions failed to start when the application required a library version that was not available for the application’s AIMMS version. PRO now checks for this when you publish the application. If a required library is not available, publishing fails with an error message naming the missing library. To resolve this, update the library to a version that works with your application’s AIMMS version, then publish again.
AIMMS PRO 26.6.2 Release
On August 13, 2026 we released AIMMS PRO 26.6.2(Cloud build: 26.6.2.2)
Improvements
Faster app startup when using authentication functions: Calls to pro::authentication:: functions during app startup could take up to 15 seconds, causing a noticeable delay before the app became usable. This has been fixed by introducing a more efficient method for listing group, user, and environment relations. Authentication calls are now significantly faster, resulting in quicker startup times.
Resolved Issues
Apps that display past runs or sessions could time out when loading that list, especially for heavily used apps. This is now fixed — session lists load significantly faster.
Fixed an issue where WinUI apps published with AIMMS 4.98 or lower cannot launch on Cloud.
AIMMS PRO 26.6.1 Release
On July 23, 2026 we released AIMMS PRO 26.6.1(Cloud build: 26.6.1.1)
Improvements
New toolset support: Added support for a new compiler toolset, in preparation for upcoming AIMMS and AutoLib releases that will use it.
Frozen binaries updated for the old toolset: The frozen binaries used for the old toolset have been updated.
