Managing Secrets
The AIMMS PRO REST API is extended with a new API service called secret-manager, which provides APIs for secure storage and management of customer and user secrets within the PRO environment.
The full OpenAPI specification of this service can be downloaded in YAML/JSON format from the link https://[account-name].aimms.cloud/pro/secret-manager/v1/openapi.yaml.
Service Endpoint: https://[account-name].aimms.cloud/pro/secret-manager/v1
Items are the primary resources managed by the service and are of two types,
Directory: A container that can hold directories and secrets
Secret: A leaf resource that stores sensitive content
Operations supported by secret-manager REST API to manage items,
GET /pro/secret-manager/v1/item/{path}- To get an itemPOST /pro/secret-manager/v1/item/{path}- To create an itemPATCH /pro/secret-manager/v1/item/{path}- To modify an itemDELETE /pro/secret-manager/v1/item/{path}- To delete an item
By default root directory(/) is already created and available to all Admin users. Non-admin user has access to nothing, so access must be given to the root directory first of all.
Items can be accessed by AIMMS PRO users and groups. Only Admin users are allowed to manage access of any item using following operations,
GET /pro/secret-manager/v1/access/{path}- To get entities with access to an itemPUT /pro/secret-manager/v1/access/{path}- To create/modify an access entityDELETE /pro/secret-manager/v1/access/{path}- To delete an access entity
Item Access Management
Only Admin users can manage access for any item.
Item access can be configured at either the group level or the user level.
When an item is created, it inherits access permissions from its parent directory. Parent permissions are used only at creation time and do not grant implicit access afterward.
Access is always evaluated on the resource itself, not on parent directories.
- Access Types for directory:
read access: Allows listing items under the directory only
read_write access: Allows listing items, creating new items under the directory and deleting empty directory
- Access Types for secrets:
read access: Allows reading the secret content only
read_write access: Allows reading, modifying and deleting the secret
