Legacy Sessions
The WebUI and Solve sessions recorded before the new Sessions page was introduced can be found under Legacy Sessions. Task sessions are listed on a separate page, Tasks.
If you are an administrator, you will not only see your own sessions but also all sessions created by other users.
Tabs Overview
WebUI: View and manage sessions involving the the use of AIMMS WebUI applications.
Solver: View and manage sessions related to solver activities (e.g., optimization sessions).
../_images/newportal-leagcy-sessions.png
Usage
Terminating Active Sessions
You can terminate active sessions that are still running, either because they are taking too long or are no longer needed.
Inspecting Sessions
Terminated, failed, or completed sessions remain visible in the portal. This allows you to review session history, understand usage patterns, or investigate issues through associated logs.
In addition to reviewing session details, you now have access to two new options in the session context menu:
Session log: Opens a detailed log of activities that occurred during the session. This is useful for troubleshooting errors, tracking execution steps, and understanding session behavior. Within the session log view, you also have the option to Download log, allowing you to save the log content for offline analysis or sharing with others.
../_images/session_logs.png
These options enhance your ability to analyze individual sessions more effectively.
Deleting Sessions
Once you have reviewed a session’s outcome or no longer need the information, you can delete it by yourself or they will be automatically deleted after a certain period. By default, sessions older than 30 days are automatically removed.
To change this setting:
  • Go to Configuration > Retention Settings
  • Adjust the Session retention time to your preferred duration.
  • Retention settings are applied to WebUI and Solver sessions.
  • Deletion is only possible for terminated/finished/completed sessions.
Filtering & Sorting Sessions
The Sessions page provides filtering and sorting tools to help you quickly locate the sessions you need.
Sorting Sessions
  1. Open the column menu by clicking on the filter/sort icon next to a column header.
  2. Under Sorting, choose one of the options: No sorting, Ascending, Descending.
  3. Click Apply to update the table.
Sorting can only be applied on one column at a time. If you apply sorting on another column, the previous sorting is automatically cleared.
Filtering Sessions
  2. Under Filter, enter or select a value for that column. For example, you can filter by Session ID, State, Application Name/Version, or created(date/time).
  3. Multiple filters can be applied across different columns at the same time.
  4. Use Clear all to remove filters for that column.
Exporting Session Data
You can now export the session data displayed on the Sessions page for offline analysis or reporting. The Export Table option is available under the three-dot menu(⋮) on each tab of the Sessions page. The session data will be downloaded as a CSV file containing all columns.
WebUI Sessions
The WebUI Sessions tab displays a table listing all sessions initiated by users. Each row contains the following information:
Column
Session ID
Unique identifier assigned to the session.
State
Status of the session (e.g., terminated)
Application
Name and version of the application associated with the session.
Owner
The user who initiated the session.
Created (GMT+2)
Timestamp indicating when the session was started.
../_images/webui_sessions.png
Manage WebUI Sessions:
To manage individual sessions, right-click a session row to open the context menu with the following options:
  • Session log (disabled for queued sessions): View or download detailed logs of the session’s activity.
  • Terminate (disabled for already terminated sessions): Ends an active session.
  • Delete: Permanently removes the session record from the list.
Solver Sessions
The Solver Sessions tab provides insight into all computational solver sessions triggered by users or applications. Each row contains the following information:
Column
Session ID
State
Status of the session (typically finished)
Application
Descrption
Typically includes case or scenario details passed during execution.
Owner
Created (GMT+2)
Timestamp indicating when the session was created.
Run Time
Total time the model was solving.
Queue Time
Time the session spent in the execution queue before starting.
../_images/solver_sessions.png
Manage Solver Sessions:
Task Sessions
Task sessions are available on the dedicated Tasks page.
