AIMMS command line options
Calling AIMMS
On the AIMMS command line, you can specify a number of options and arguments that will influence the manner in which AIMMS is started. The following line illustrates the general structure of a call to the AIMMS program.
aimms.exe [command-line-options] [project-file [session-arguments]]
Command line options
Table 3 provides an overview of the command line options that you can specify. AIMMS offers both long and short option names, and some options require a single argument. All short option names start with a single minus (-) sign, followed by a single character. By convention, short options that require an argument use capital characters. The long option names are always preceded by a double minus sign (--), followed by a descriptive text. In general, the long option names are easier to remember, while the short names permit a more compact command line. Short option names without an argument may be appended one after another with only a single minus sign at the beginning.
Long name |
Short name |
Argument |
--user |
-U |
user[:password] |
--backup-dir |
-B |
backup directory |
--log-dir |
-L |
log directory |
--config-dir |
-C |
configuration directory |
--license |
license name |
--license-wait-seconds |
seconds to wait |
--run-only |
-R |
procedure name |
--user-database |
user database file maximum number of threads |
--minimized |
-m |
--maximized |
-x |
--hidden |
--as-server |
--end-user |
-e |
--no-solve |
--help |
-h |
--unpack-folder |
unpack folder |
--export-to |
export aimmspack/folder |
Specifying a user
When an AIMMS project is linked to an end-user database (see Project Security), you must log on to the project before being able to run it. Through the --user command line option, you can specify a user name and optionally a password with which you want to log on to the system. When you specify just a user name, a log on screen will appear with the provided user name already filled in. If you specify a password as well, AIMMS will verify its correctness and skip the log on screen altogether if the user name- password combination is acceptable. Providing both the user name and the password is not recommended for interactive use, but may be convenient when you want the model to run unattended.
Backup and log directories
With the --backup-dir and --log-dir options you can override the default directories where AIMMS will store temporary information such as case and model backups, the AIMMS and solver listings, and the message log. You can modify the defaults for these directories using the project options dialog box (see AIMMS execution options).
AIMMS configuration
By default, AIMMS stores a number of global configuration files, such as the AIMMS license file and the solver configuration file, in the common application area of your computer. If you want to store configuration files in a different location, you can indicate this through the --config-dir option. You can use this option, for instance, to indicate where the configuration files for your particular machine can be found when the AIMMS system that you use is stored on a network disk, and when you do not use a license server.
License name
Through the --license option you can select any AIMMS license that you installed in the AIMMS License Configuration dialog box. The value that you specify for the --license option should match an entry in the License column in the left pane of the License Configuration dialog box. In case you are using a network license with different profiles, you should make a different entry in the AIMMS License Configuration for each profile you want to use and you can use the --license option to open AIMMS with a license with a specific profile.
Network logon timeout
When you are using a network license, the license server may not have a license available for you right away. Through the --license-wait-seconds option you can specify the number of seconds you want AIMMS to wait for a network license to become available. If you do not specify this option AIMMS will use a default timeout of 0 seconds. When reaching the given timeout, AIMMS will try the next license in your license configuration, or will return with a license error if no other licenses are available.
User database location
When your application has been set up for use by multiple users, all user and group information associated with the application is stored in a separate (encrypted) user database (see User authentication and authorization for more details on this topic). Through the --user-database option you can move the location of this user database file (to for example a single location that is shared among all users on the network) even though you might not have developer rights to the application.
Limiting the number of parallel threads
Through the option --max-threads you can specify the maximum number of (virtual) cores that AIMMS is allowed to use during the execution of statements, the evaluation of definitions or during a parallel solve. By default AIMMS uses the number of cores that are available on the machine, but during a heavy load of multiple processes it might be beneficial to limit the number of cores that AIMMS will use. This option is ignored if you set it to a value that is larger than the actual number of cores.
Running minimized, maximized, hidden, or as server
Through the --minimized, --hidden and --maximized options you can
indicate whether you want AIMMS to start in a minimized or hidden state
(i.e. just as a button on the task bar, or not visible at all), or to
fill up the entire screen. Running AIMMS minimized or hidden may be
convenient when AIMMS is called non-interactively from within another
program through the AIMMS API (see The AIMMS Programming Interface of the Language
Reference). In this way, your program can use AIMMS to solve an
optimization model after which it resumes its own execution. The
--as-server option extends the --hidden option, and should be
used when AIMMS is started with limited privileges by a system service
(e.g. through the Internet Information Server). It suppresses all dialog
boxes that may appear during startup of AIMMS, as well as during the
execution of your model.
Developer versus end-user mode
With the --end-user option you can force AIMMS to start up a project in end-user mode using a developer license, allowing you to preview your application as if you were an end-user without the need to explicitly export an end-user project. Please note that the option to emulate end-user model using an AIMMS developer license will not work, unless it has been enabled in your AIMMS developer license.
Exporting an end-user project
Through the --export-to option you can instruct AIMMS to create an encrypted end-user project either packed to the AIMMSfile file specified, or unpacked into a specified folder. When using this commandline option, AIMMS will use the export settings as saved by the previous call to the File-Export End-User Project menu. You can use this commandline option, for instance, within the context of a continuous integration server, to automate the deployment of your AIMMS application after new commits have been pushed to the version control repository managing the project.
Specifying the unpack folder
When running an AIMMSfile file, AIMMS will ask for the folder where you want the AIMMSfile file to be unpacked. Alteratively, you can already specify the unpack folder through the --unpack-folder commandline option.
Solverless AIMMS sessions
AIMMS strictly enforces that the number of AIMMS sessions with full solving capabilities running on your computer simultaneously is in accordance with your AIMMS license. Typically, for a single-user license, this means that you can only start up a single AIMMS session that is capable of solving optimization programs at a time. However, for every fully capable AIMMS session, AIMMS also allows you to start up an additional AIMMS session without solving capabilities. You can use such a session, for instance, to make modifications to your model, while a first session is executing an optimization run. In that case, AIMMS will present a dialog box during start up to indicate that the session has no solving capabilities. You can suppress this dialog box, by specifying the --no-solve command line option.
Executing a procedure and terminating AIMMS
When you want to run an AIMMS project unattended, you can call AIMMS
with the --run-only option. This option requires the name of a
procedure in the model, which will be executed after the project is
opened. When you use the --run-only option, all other initial project
settings, such as the initial case, procedure and page settings, will be ignored. AIMMS will, however, call
the procedures MainInitialization, PostMainInitialization,
PreMainTermination, MainTermination, and all library
initialization and termination procedures as usual. Once the procedure
has finished, the AIMMS session will be terminated. You can only specify
the --run-only option if you also specify a project file on the
command line.
Opening a project to run
AIMMS will interpret the first non-option argument on the command line as the name of the project file with which you want to open AIMMS. If you specify a project file, the settings of the project may initiate model-related execution or automatically open a page within the project.
Opening a project to edit
If you want to open a project for editing purposes only, you should hold down the Shift key when opening the project. The initial actions will also not be performed if the command line contains the --run-only option. In this case execution takes place from within the specified procedure only.
Passing session arguments
Directly after the name of the project file, AIMMS allows you to specify
an arbitrary number of string arguments which are not interpreted by
AIMMS, but can be used to pass command line information to the project.
In the model, you can obtain the values of these string arguments one at
a time through the predefined function SessionArgument, which is
explained in more detail in Execution Control Functions.
Example
The following call to AIMMS, will cause AIMMS to start the project
called transport.aimms in a minimized state using the user name
batchuser with password batchpw, run the procedure
ComputeTransport, and subsequently end the session. A single
argument "Transport Data" is provided as a session argument for the
model itself.
aimms --minimized --user batchuser:batchpw --run-only ComputeTransport \
transport.aimms "Transport Data"
Note that the \ character at the end of the first line serves as the
continuation character to form a single command line. Using the short
option names, you can specify the same command line more compactly as
aimms -mUbatchuser:batchpw -RComputeTransport transport.aimms "Transport Data"
In this command line, the -m and -U options are combined. No
space is required between a short option name and its argument.
Using session arguments
Given the above AIMMS call, you can use the function SessionArgument
to fetch the first session argument and assign it to the string
parameter ODBCDataSource as follows.
if ( SessionArgument(1, ODBCDataSource) ) then
* Execute a number of READ statements from ODBCDataSource
endif;
Following this statement, the string parameter ODBCDataSource will
hold the string "Transport Data". In this example, the string
parameter ODBCDataSource is intended to serve as the data source
name in one or more DATABASE TABLE identifiers, from which the input
data of the model must be read.
