Page Options
You can access the page options via the ‘options wheel’ in the WebUI Menu Bar page-settings.
Currently, the following options for a page are available:
  • Procedure (for specifying a procedure that should be run upon opening the page)
  • MaxColumns
  • A number of advanced options (not documented here).
Maximum Number of Columns
You may find that when you change your window size, the widgets re-arrange too often. A simple way to prevent this is to limit the maximum number of columns. You can do this via the ‘page settings’ icon cog-grey just to the right of the page name. At the miscellaneous tab you can edit the maxcolumns setting. The maximum value that this setting can have, is 14 columns.
Last Updated: April, 2019
