AIMMS to ODH Mapping
ODH engine options
The table below shows in the left column the AIMMS options that control the ODH engine; the right column displays for each AIMMS options the associated ODH-CPLEX parameter.
Option name in AIMMS
Name in ODH-CPLEX
Backtrack Limit
MAXBACKTRACK
Decomposition Density
DECOMPDENSITY
Global Bounds
GLOBALBOUNDS
Initial Divisor Value
INTERDIV
Initial Divisor Value Sub Models
DIVISOR
Maximum Divisor Repeats
MAXREPEAT
Maximum Divisor Repeats Infeasible
MAXINFREPEAT
Maximum Divisor Value
MAXINTERDIV
Optimization Method
FEASOPT
Write Decomposition File
Clean Variables Sub Models
VARIABLECLEAN
Objective Target
OBJTARGET
ODH Feasibility Tolerance
FEASTOL
ODH Presolve
ODHPRESOLVE
ODH Seed
SEED
Presolve
PRESOLVE
Quick First Solve
QUICKFIRSTSOLVE
Reject Infeasible Solutions
REJECTINFSOL
Relax SOS2
RELAXSOS2
Remove Infeasibilities Method
PHASE12
Search Mode
Write Solution File
WRITESOLUTION
First Feasible Heuristic
FIRSTFEAS
First Feasible Heuristic Continue
FIRSTFEASCONTINUE
First Feasible Heuristic Effort Level
FIRSTFEASEFFORT
First Feasible Heuristic Shift
FIRSTFEASSHIFT
Recurse
RECURSE
Recurse Decomposition Method
RECURSEDECOMP
Recurse Iteration Limit
RECURSEITERLIM
Recurse Iteration Limit Solution
RECURSESOLITERLIM
Recurse Minimum Iterations
RECURSEMINITERLIM
Solution Improvement Heuristic Mode
DETERMINISTIC
Solution Improvement Heuristic Penalty
PENALTY
Solution Improvement Heuristic Strategy
STRATEGY
Recurse Log
RECURSELOG
Status Display
Thread Log
THREADLOG
Thread Limit
THREADS
Thread Synchronization Frequency
SYNCFREQ
Processor Lock
PROCESSORLOCK
CPLEX solve options
The two tables below show options used by ODH-CPLEX for the main CPLEX solve in ODH-CPLEX (if the Search Mode is set to ‘Global Solution’) or for getting an initial feasible solution (if the Search Mode is set to ‘Local Solution’).
Name in ODH-CPLEX for main CPLEX solve
Barrier Algorithm
CPX_BARALG
Barrier Convergence Tolerance
CPX_BAREPCOMP
Barrier Crossover Algorithm
CPX_BARCROSSALG
Barrier Density Definition
CPX_BARCOLNZ
Barrier Growth Limit
CPX_BARGROWTH
Barrier Iterations
CPX_BARITLIM
Barrier Maximal Number of Corrections
CPX_BARMAXCOR
Barrier Objective Range
CPX_BAROBJRNG
Barrier Ordering
CPX_BARORDER
Barrier Start Algorithm
CPX_BARSTARTALG
Advanced Start
CPX_ADVIND
Cleanup Coefficients
Clock Type
CPX_CLOCKTYPE
Conflict Algorithm
CPX_CONFLICTALG
Data Check and Modeling Assistance
CPX_DATACHECK
Deterministic Time Limit
CPX_DETTILIM
LP File
Memory Emphasis
CPX_MEMORYEMPHASIS
MPS
Numerical Emphasis
CPX_NUMERICALEMPHASIS
Ord File
Random Seed
CPX_RANDOMSEED
Round Coefficients
Sav File
Scale
CPX_SCAIND
Sifting Algorithm
CPX_SIFTALG
Updates Batch Size
Barrier Display
CPX_BARDISPLAY
Clone Log Files
CPX_CLONELOG
MIP Display
CPX_MIPDISPLAY
MIP Interval
CPX_MIPINTERVAL
Simplex Display
CPX_SIMDISPLAY
Backtrack
CPX_BTTOL
Branch
CPX_BRDIR
Difference Objective
CPX_OBJDIF
Integrality
CPX_EPINT
Maximal Number of Nodes
CPX_NODELIM
MIP Basis
MIP Candidate List
CPX_STRONGCANDLIM
MIP Dive Strategy
CPX_DIVETYPE
MIP Emphasis
CPX_MIPEMPHASIS
MIP Method
CPX_SUBALG
MIP Probing
CPX_PROBE
MIP Search Strategy
CPX_MIPSEARCH
MIP Start Algorithm
CPX_STARTALG
MIP Tree Memory Limit
CPX_TRELIM
MIP Update
Node File
CPX_NODEFILEIND
MIP Node Presolve
CPX_PRESLVND
Number of Parallel Threads
CPX_STRONGTHREADLIM
Number of Repair Attempts
CPX_REPAIRTRIES
Number of Simplex Iterations
CPX_STRONGITLIM
MIP Priority Order Switch
CPX_MIPORDIND
MIP Priority Order Type
CPX_MIPORDTYPE
Probing Time
CPX_PROBETIME
Probing Time Deterministic
CPX_PROBEDETTIME
Relative Difference Objective
CPX_RELOBJDIF
Select Variables
CPX_VARSEL
Selection of Nodes
CPX_NODESEL
Working Memory Limit
CPX_WORKMEM
Write MIP Starts
SubMIP Node Limit
CPX_SUBMIPNODELIMIT
SubMIP Scale
CPX_SUBMIPSCAIND
SubMIP Start Algorithm
CPX_SUBMIPSTARTALG
SubMIP Subproblem Algorithm
CPX_SUBMIPSUBALG
BQP Cuts
CPX_BQPCUTS
Clique Cuts
CPX_CLIQUES
Cover Cuts
CPX_COVERS
Cut Generation Limit
CPX_AGGCUTLIM
Cut Limit
CPX_EACHCUTLIM
Cuts Factor
CPX_CUTSFACTOR
Disjunctive Cuts
CPX_DISJCUTS
Flow Cover Cuts
CPX_FLOWCOVERS
Flow Path Cuts
CPX_FLOWPATHS
Gomory Cuts
CPX_FRACCUTS
Gomory Cuts Candidate Limit
CPX_FRACCAND
Gomory Cuts Pass Limit
CPX_FRACPASS
GUB Cover Cuts
CPX_GUBCOVERS
Implied Bound Cuts
CPX_IMPLBD
Lift and Project Cuts
CPX_LANDPCUTS
Local Implied Bound Cuts
CPX_LOCALIMPLBD
MCF Cuts
CPX_MCFCUTS
MIP Number of Cut Passes
CPX_CUTPASS
Mixed Integer Rounding Cuts
CPX_MIRCUTS
Node Cuts
CPX_NODECUTS
RLT Cuts
CPX_RLTCUTS
Zero Half Cuts
CPX_ZEROHALFCUTS
Feasibility Pump Heuristic
CPX_FPHEUR
Heuristic Effort
CPX_HEUREFFORT
Heuristic Frequency
CPX_HEURFREQ
Local Branching Heuristic
CPX_LBHEUR
RINS Heuristic Frequency
CPX_RINSHEUR
Boundstrength
CPX_BNDSTRENIND
Coefficient Reduction
CPX_COEREDIND
Preprocessing Symmetry
CPX_SYMMETRY
Presolve Relaxed MIP
CPX_RELAXPREIND
Repeat Presolve
CPX_REPEATPRESOLVE
SOS1 Reformulations
CPX_SOS1REFORM
SOS2 Reformulations
CPX_SOS2REFORM
Polishing Absolute MIP Gap
CPX_POLISHAFTEREPAGAP
Polishing Number of Nodes
CPX_POLISHAFTERNODE
Polishing Number of Solutions
CPX_POLISHAFTERINTSOL
Polishing Relative MIP Gap
CPX_POLISHAFTEREPGAP
Polishing Time
CPX_POLISHAFTERTIME
Polishing Time Deterministic
CPX_POLISHAFTERDETTIME
Do Populate
Pool Absolute Objective Gap
CPX_SOLNPOOLAGAP
Pool Capacity
CPX_SOLNPOOLCAPACITY
Pool Intensity
CPX_SOLNPOOLINTENSITY
Pool Relative Objective Gap
CPX_SOLNPOOLGAP
Pool Replacement Strategy
CPX_SOLNPOOLREPLACE
Populate Time Limit
Population Limit
CPX_POPULATELIM
Network Feasibility
CPX_NETEPRHS
Network Iterations
CPX_NETITLIM
Network Optimality
CPX_NETEPOPT
Network Pricing
CPX_NETPPRIIND
Auxiliary Root Threads
CPX_AUXROOTTHREADS
Global Thread Limit
CPX_THREADS
Parallel Mode
CPX_PARALLELMODE
Aggregator
CPX_AGGIND
Dependency
CPX_DEPIND
Folding
CPX_FOLDING
Limit Substitutions
CPX_AGGFILL
Number of Iterations in Presolve
CPX_PREPASS
Preprocessing Reduction Types
CPX_REDUCE
Presolve Pass Dual
CPX_PREDUAL
Adjust MIQP
CPX_QPMAKEPSDIND
Barrier Convergence Tolerance for QCP
CPX_BARQCPEPCOMP
MIQCP Strategy
CPX_MIQCPSTRAT
QP Linearization
CPX_QTOLININD
QP Method
CPX_QPMETHOD
QP Nonzeros Read Limit
CPX_QPNZREADLIM
Solution Target
CPX_OPTIMALITYTARGET
Crash Ordering
CPX_CRAIND
Dual Pricing Algorithm
CPX_DPRIIND
Dynamic Row Management
CPX_DYNAMICROWS
Feasibility
CPX_EPRHS
Markowitz
CPX_EPMRK
Optimality
CPX_EPOPT
Perturbation Constant
CPX_EPPER
Perturbation Indicator
CPX_PERIND
Pricing
CPX_PRICELIM
Primal Pricing Algorithm
CPX_PPRIIND
Refactor
CPX_REINV
Sifting from Simplex
CPX_SIFTSIM
Singular
CPX_SINGLIM
Stalled Iterations
CPX_PERLIM
The table below shows Solvers General options that are mapped to ODH-CPLEX parameters.
Name in ODH-CPLEX
Cutoff
CPX_CUTLO
CPX_CUTUP
Maximal Number of Integer Solutions
CPX_INTSOLLIM
MIP Absolute Optimality Tolerance
CPX_EPAGAP
MIP Relative Optimality Tolerance
CPX_EPGAP
Iteration Limit
CPX_ITLIM
Time Limit
TIMELIMIT
Heuristic sub-model options
The heuristic sub-model parameters can only be set using a Parameter File. The syntax for the parameters that influence the heuristic sub-model CPLEX solves is the following: SUB_<parameter> where <parameter> refers to the ODH-CPLEX name in the second table above. The syntax for the parameters that influence the heuristic sub-model CPLEX solves in Phase I is the following: PHASE1_<parameter>.
For example, SUB_CPX_RINSHEUR specifies the RINS heuristic frequency for CPLEX if it used to solve a heuristic sub-model, while PHASE1_CPX_RINSHEUR specifies the RINS heuristic frequency for CPLEX if it used to solve a heuristic sub-model in Phase I.
Learn more about
