Border
The border of an object consists of two parts:
The border style, which is either a solid line or a shadow line. The latter can make an object appear raised (out shadow) or sunken (in shadow). It is also possible to have no border. If you select a border style, you can also specify the width (thickness) of the border.
A margin that separates the actual object contents from the border style. The top, left, bottom and right margins can be specified individually.
Every newly created object initially uses the default border style. You can set this default border in the Border tab, using the small menu that appears when you press the
button. This menu contains two commands:
Set as default: this will set the currently specified border as the default border (that is used when a new object is created).
Reset to default: this will set all border properties according to the current default border.
