Maximize Attribute Window
When you are making large edits in a specific field of an attribute window (for example when specifying the body of a procedure), the specific field within the window may be too small to edit conveniently. Therefore, AIMMS allows you to maximize such a field within the attribute window, by selecting Maximized from the Edit menu or click the Maximize button
in the toolbar. When you have maximized a specific attribute field, this field is resized to fit the entire attribute window (temporarily hiding the other attributes). Additionally, this maximized field is equipped with a horizontal scrollbar. To go back to the regular attribute window, you can once again select Maximized from the Edit menu or click the Maximize button
in the toolbar again, or click the Restore normal size button
at the top-right of the window.
Only attributes that accept multiple lines of input can be maximized.
